Ok guys,my air con rattles when i hit the snowflake,goes off when i disengage it. Its gone from intermitant to nearly full time.Any ideas? Still blows cold air and does what it should just rattles like #####.HELP!
It's likely to be the compressor or electromagnetic clutch on it given the symptoms as they are the only rotational mechanical parts in the system.
Guest DazH
Indeeeeeeeed correct. Fire up the A/C, pop the bonnet and listen around the compressor area to be sure!
Press some grease into the air-con pulley (careful not to get it on belt area !!)
Blessing in disguise ! Rip that sucker (and its belongings) out ;)
  • 2 months later...
New compressor and recharge it is then :P :lol:
