New To Bmw (Just Clicked Buy It Now On Ebay!)
Good morning Dave True, the one I got ad 79k, full BMW service history and I had to replace almost all gaskets, o rings, hoses, abs sensors, seals, and I still don’t have a fault free car. Although I have just serviced the car, it looks that I should replace the oil sensor just to be on the safe side, I am using the car for family holidays so the last thing I want is to be stranded. Thank you for the support. Very much appreciated!! Take care Dimitri -
2008/09 520d
17
17
Hello Dave. I don’t know if it will stop the engine from running, I read it in one of the BMW forums. The strange thing is that I don’t get a fault on my dash!! only on the OBD. I got my first 735 last August, loved it from the first ride, and now I am trying to fix all those little things that the main BMW dealer have not bothered to put right, hence my questions. Almost there!! Many thanks Dimitri
