Dc 13 Pics..............
X5 wanted
I have a 2003 for sale. email me if you like to chat. thank you John. -
Hi Ali Have you checked that the battery holding clamp is in place ? When the battery was changed was swapped like for like? Dave -
Hi Guys, I’m after a bit of advice here! I have changed the battery and now all of a sudden i’m getting the “Battery Restraint Malfunction” warning on the dashboard. When I go to clear the code and restart the engine the warning comes straight back on. Any ideas what to check first? Thanks in Advance. Ali -
Dashboard lights failure
Morning Stu The fact you have a wiper issue would point me away from the Cluster initially My thoughts are Footwell Module it's in the left hand footwell (well it would be 😅) Run a scan it should show up any issues. The Footwell control module on the 4.6 caused all sorts of odd stuff radio that would randomly turn on/off odd light issues seat controls. BMW say you can't swap them it has to be new and set up by them (wrong of course) I changed mine for an upgraded unit second hand it took longer to remove the old unit and swap it than it did to re-program it cured everything and probably stuff I hadn't found 😅 Dave P.S I wont let the E70 on Whats App or Face Book just in case 🤣- 1
