Just got myself a 1series knowing the injectors are slightly playing up. When sitting idle can feel it. Does anyone know if cleaning products when filling up with diesel work? Or shal I avoid? Thanks
i have heard they do a lot more harm than good...is your car spluttery or rubbish mpg?
It's running good and when sitting idle that car sum times drops revs just a little. The fuel seams fine. The previous owner had 1 injector replaced and said there's 4? And he thinks 1 more might b playing up. Was wondering "as its a diesel" might be se rubbish in it. Was thinking of a cleaning agent and long drive? Thanks
Welcome to BMWOC matey.
The injectors should not be acting up on a 2005 vehicle. If they are, they are faulty and cleaning will most likely do no good. If you are to get them cleaned, you will need to remove them and have them professionally ultrasonically cleaned with the spray patterns dictating whether they are faulty or not. This will cost you around £200 from a third party company.
Fuel additives are known within the industry to be hogwash
To be honest, I believe it to be unlikely the injectors at fault. Best advice anyone can give you is get the ECU scanned. If it only happens at idle, it may be an ignition/idle control issue
All the best,
Daz
Thanks all for welcoming me. And to mart77 I don't knw if I knocked sumat but just noticed the thumb is down. Sorry dont knw if that was me m8
no probs mate <_<
      Tyres for front of my 240i
    5. 0
      520d advice
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
