just asking what means would you use to clean a cone air filter heard different ideas thought it would be good to through the question onto the forum for your ideas.
A decent quality cone air-filter should have been coated in a special oil from the factory. A good knock against something solid should clear anything. If you want to give it a good ol' clean, soak it in soapy water but if you do this, it is advised to re-coat it with the oil again.
http://www.ebay.co.uk/itm/99-5050-K-N-AIR-FILTER-RECHARGER-KIT-CLEANER-NEW-OIL-FREE-K-N-STICKER-PACK-/380658915286?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item58a10a17d6
Hope this helps mate
Daz
      3.0i starter motor
    4. 0
      Bmw x1 2012 won't start
    5. 6
      X3 2.0 automatic
    • BLM06 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
    • Karlos70 earned a badge
