Hey Tim,
All should be okay. Gav has similar Style 32 alloys on his 320d so, yeah...
Wait for someone to give the go ahead first mate. I'm not 100%
Daz
Currently running std height though that will change in the next 6 months. The offset is 15 which concerns me.
Now I have lowered my E36 there is about 4mm gap between the inside of the wheel and the coilover collar with the spring wound up pretty tight. Not sure if you would run into a similar problem on the E46 with them wheels without running spacers.
I'm running an offset of 25 on 8j 9j staggered
-100 mm front
-70mm rear no problems
But I have 215/35/18 all round
      Sat/nav 8.8 screen upgrade
    3. 13
      Air bag fault
    • Mish earned a badge
    • Bmw90 jack earned a badge
