Hello From Dorset
Remapping
Hi new to this site but wanted some opinions on whether you really need a gearbox remap after a ecu remap on my 335d x drive if i did? Wanted to know what you guys think? 🤨😁 -
My x5 blew through the expansion/ filler leaving me stranded. Have a look through the forum. I had to get the car recovered home. -
engine judder while idle
My 116 has developed a judder under idle like a injection fault but I've had it on a scan tool no faults found anybody got any ideas -
Battery Restraint Malfunction / Battery change
So update… clamp is in place, like for like and battery re-coded. I have tried to clear the faults via obd and fault remains. 🤦♂️ Any other ideas?? -
Morning Paul Unfortunately BMW as did many other manufacturers started fitting plastic parts not just externally but also internally and with many heat cycles they become brittle as they age I have seen the the Header tank on a friends Mercedes his was just under the cap around the neck so only showed when the engine was really hot. When I rebuilt the 4.6 (plastic chain guides Failed) I found several coolant "O" rings in the coolant system were starting to weep. BMW wanted to sell complete hose assemblies but many of the parts I sourced were from the USA (Dinan) new Cams,Throttle body gasket sets amonst them were a set of Viton Coolant system "O" rings worth checking those as well. Good Find Dave
