Hi. Got a problem with my gears, Today, i had to stop and reverse quickly, so away i go when i suddenly felt a big "clunk", since then, when in "D" as soon as i pull away in first it slips out..if i stop and move it to "S" same thing. I can however move it to "+/-" (tiptronic) and pull away in first, change to second 3r d etc.. . What has also happened is it came up with "Trans Failsafe Prog", and seemed to restrict the gears to 3,4 and 5 gears only.
Can someone tell me whats going on?
Regards
Rich
You've upset it !
Any movement in the shifter ?
Hi,
  On 7/16/2013 at 6:34 PM, Jack Dabsy said:
You've upset it !
Hi, if you mean does the gear selector knob feel loose, then No, still feels the same.
Rich
      Alloy wheels
