Hi can anybody help me ? I have a 2006 320d touring with a BMW professional radio fitted.
The problem is when I go into the menu there is no icon for the phone, am I missing something or just being stupid ? The aux plug in glove box works for Music and the steering controls work but I really want to be able to connect my phone by Bluetooth, any ideas ? ..
Check the boot... Are the Phone and BT modules present?
Hi Jack thanks for getting back to me. Just checked in the boot and found a MULF module. Not sure if this makes a difference but seem to remember garage changing radio just before I brought the car (old one faulty). Do they have to be coded to match module ?
Hi Jack should have mentioned the HU does not pick up the the cd multi-changer in the boot either, don't know if this is connected in any way.
One way you can be sure your HU has BT on it, is to take it out from the centre dash console and check the backplate. It should have a BT sticker on it. If it doesn’t there’s another way. Run the part number from the backplate against http://www.realoem.com database and see what comes up.
Hi everyone thanks for your help. Just took my car to a local garage and he had some software which he plugged in and checked out my car,.It turned out the HU came from a car that didn't have Bluetooth or a cd multi changer. so he re-set the settings and everything works ok
      Bmw 116d 2011 her fault codes
    2. 4
      Misfire at 2000rpm
      Misfire at 2000rpm
      Noise
    • welshchy earned a badge
    • Michal earned a badge
    • JohnLC earned a badge
    • rjrive earned a badge
