So I live in Russia, and imported a 2010 X5 from Germany.
The car has the massive phone cradle in the arm-rest box between the seats. As a lot of the iAssist etc services don't work in Russia and that it was taking up so much room, i un-screwed it and cut the wires...
Now I'm getting the SOS fault light coming up all the time.
Please someone tell me how to remove it? Do I have to reset the iDrive? Or take it to the dealer?
Thanks very much!
Will
Where, exactly did you hack the loom?
Reset will be necessary in any case ;)
  • 2 months later...
I'm my opinion the vehicle will need to be connected to a diagnostic machine.
A Autologic tool will be able to disable the SOS or telematics module.
Do you have the Bluetooth phone solution?
SOS normally only flags up when there is a whole in the fibre ring.
Cheers
Jono
      Bmw 116d 2011 her fault codes
    2. 4
      Misfire at 2000rpm
      Misfire at 2000rpm
      Noise
    • welshchy earned a badge
    • Michal earned a badge
    • JohnLC earned a badge
    • rjrive earned a badge
