Harris Hospice Car Show 8Th Sept 2013
DPF Cleaning fluid
Hi guys here's the latest. I drove to Glasgow and back today. Around 40 miles of dual carriageway each way and kept the revs between 2500 and 3000 approx. I kept it in fourth gear as much as possible. I also kept an eye on the temp which hovered between 68 and 74 degrees each way. My son in law put his Carly on it while I was there and cleared the EGM light and the DPF fault. the DPF returned on the way home but not the EGM. When I purchased this car 7 years ago it had the DPF light on and it turned out the problem was solved by replacing a faulty thermostat which was preventing the engine regenerating due to low running temperature. I think it warrants investigation as it cured the problem then. Any other thoughts? thanks Paneuro. -
Z4 5 speed auto transmission problem
Recently acquired a 2.2ltr 2005 Z4 at a price which I could not resist if though it had little or no drive through the transmission. Diagnosed a fluid leak so off came the sump, changed the fluid filter, fitted a new gasket and a new transmission seal to the output shaft put it back in only to find a pool of fluid on the garage floor the next day. My only thoughts now are that the fluid pump may be leaking so I should change the gasket on this as well? Anyone else encountered this problem before? I welcome any advice/suggestions as to how to fix this issue. -
Hi everyone, I’ve noticed an oil leak coming from the turbine outlet flange area on my BMW 320d xDrive G21 (2019, B47 engine). The oil seems to be coming from the joint between the turbocharger and the downpipe. Has anyone had a similar experience? Any help or experience with a similar issue would be really appreciated. Thanks in advance! -
DPF Cleaning fluid
Thanks guys, I'm going to give it the beans a bit tomorrow and see how that goes. I'm trying to get into the secret menu just to get an idea if it does a regeneration while I'm driving it hard. I will let you know how it goes. Thanks Paneuro. -
Hi there just thought I would give you an update regarding my ecu. I sent it to ecutesting as recommended unfortunately they couldn't do anything with it as they said that that they didn't have equipement or tech old enough to test it with lol. They were very apologetic and sent it back to me. Additionally they didn't know of anywhere else I could send it to for testing but of the checks they did do they didn't find anything untoward. So it looks like I will have to find somewhere else or risk buying a second part either way a little bit frustrating.
