Just replaced the front passenger window in my '94 vert and it doesn't come up as far as the old window. Problem is glass sits level with rear window and it should sit 1/4 inch above to make proper seal with roof. Does anyone know how to adjust the winder height if its at all possibl
Does it go fully up with the roof down?
If the original mech hasn't been moved, then either the seal is dodgy or the glass is wrong...
Try a window "Reset" by holding "window-up" button on console and for ten secs after...
      520d advice
    3. 13
      Fuel rail pressure problems.
      Would you buy this car?
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
