Wanted: E39 540I In Black With Manual Transmission - Cash Waiting
Hello im new to the us forum and jsut want some advice please, I have BMw 3 Series M Sport F30 and I want to know if I can fit this steering wheel to my car? And if it is as simple as removing the standard m sport steering wheel and bolting the new one in place or will it need coding to the car Thankyou for your help 😊 -
Bmw 116d 2011 her fault codes
My neighbour who brought the iCarsoft reader was shocked the first time he plugged it into the car to discover it could read 21 Control Modules and over 100 sensors and related connections in the Bus system on his car so well worth the investment with even our local BMW specialist charges £120 per Hour and the Main Dealer over £200. It also alows service functions to be carried out. He is now much more adventurous with the things he can do. My advice would be if you can get a copy of INPA?ISTA up and running on a Laptop it will allow Dealer Level diagnostics If that is to ambitious then the iCarsoft system is simple to use and only one step behind, plus it is self contained no laptop needed Dave
