Newbie
Well got the 240 back yesterday, have to say excellent service from the main dealer repair centre. New wheel looks great, top pic. Wish I could afford the other 3! Going to see who can match the other ones properly. A front one pictured, not that bad I suppose. Alignment all checked etc. Glad it's back- 1
Newbie here
