Do hope someone can help me!
I noticed while on motorway a sudden change in tone! There is a dull but annoying pulsing vibration through the car which is only noticed when moving . It doesn't seem to get faster with speed!
I have had all wheels balanced but still it persists! Had it up in the air and can't see anything obvious.
Any help would be most appreciated!
Haven't tried mate! It's a low vibration, but annoying all the same!
Should I give it a try?
At speed, if it is safe to do so...
Could be the prop centre bearing (at first guess)...
Just to add... If this only happens whilst moving then its more likely to be the hubs/discs/axles or centre-bearing (in other words, the rolling gear) ;)
Hiya jack! Tried braking, no difference!!
Will check for anything obvious when I put me winter wheels on! Could still be prop bearing though you said! 😊
      filter change recomendations
    • Graham J earned a badge
    • EonT earned a badge
    • delh1982 earned a badge
    • Norberg earned a badge
