Turn the ignition key to position one. Service light and radio comes on. Turn to position two and no ignition light comes on. After turning the on/off a few times ignition light comes on but will not fire the engine. Keep turning on/off and suddenly it all works normally.
Any ideas, chaps?
"Dry" connection at the relay at a guess... Or even a temperamental ignition barrel ! :huh:
Cheers Dabsy,
What relay and any idea/number where it is?
And yea ignition switch/barrel did spring to mind.
Any thoughts of the problem being the key itself?
The important relays would be near the battery ;)
I doubt it being the key at fault (but not impossible!)
Could even be a coil issue... If "Low Tension" connection is temperamental etc.
      Would you buy this car?
      Selling a BMW wall charger
      BMW electric forum
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
    • Amk earned a badge
    • Glyn6653 earned a badge
