Hi guys I've recently bought a E60 535d its only got 80k on the clock so its not been around the world..when I purchased it off a friend mpg was stating around 27mpg, which is normal around town driving. But this driving it around town to and from work no more than 3 miles commute and the occasional 15 min commute on dual carriage way, I've noticed it just keeps dropping. Its currently at 23 mpg and thats conservative driving. Iv read other members getting near 30..i do like to put my put down and use the power once a week but it shouldnt be that bad should it?
Sny suggestions....cheers lads
Depends when it was reset to be fair. You stated you only bought it recently so for an average to become stable, time is needed.
Also, it does take time to get used to a car. I buy and sell cars regularly so I can see the difference in MPG from when I first start driving the car, then after a month or so. Driving habits like controlling the clutch and pressure applied to the accelerator make quite a large difference when the MPG is concerned. If it's manual, it will take a while for you to get to know your engine and FEEL the revs before you change gear
Reset it and bare with it :)
Also... SERVICE HISTORY!? :lol: Tells us about that
Daz
Thnks Das
Had it serviced month ago..everything came out clean..originally was bought of a auction, need to ring bmw to chase the history...its auto..will reset it.
Ive heard if the car doesn't warm up properly it can have an effect...
Also don't forget MPG is generally worse in winter due to having all the electrics on etc and engines take longer to warm up properly. May only make a small difference but could still play a part in it...
Although you say its just been serviced its best to check the air filter for yourself as it wouldn't put much faith it them changing it, also check the egr to see if it needs a good clean and get the fault codes checked for peace of mind as a faulty thermostat will reduce mpg.
Thanks mate, maybe i will have to get the egr checked make sure its not clogged up and give it a good clean..will check the air filter over the weekend. Im not going crazy tho hahaahaa it shouldnt be this bad right?
I know its winter but i always give 5 - 10 mins regardless of weather to warm the engine up before setting off and cool it down it...i spoke to someone in the car wash who had 525i and he was achieving 3mpg...inwas like WTF LOOL and he told me it was local driving...best i had not heard that....
Would love to get 27MPG. Mines does 23.1, but thats what happens when you've got a heavy right foot. I don't think that's that bad for a dual turbo diesel. Anyway, Happy New Year
      Tyres for front of my 240i
    5. 0
      520d advice
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
