Broad Oak Dealership Deception – Buyers Beware!
Newbie here
Appears no fire
Morning Larry Welcome to the Forum Sorry I can't hear the recording However your 539i runs with iBus so tracing faults with a BMW friendly diagnostic program (preferably INPA or BMW 1.4.0) so first step get a Diagnostic done. Checks to do first would be. Compression Check, Fuel Pressure at the injector rail. Fuel Pump relay, Vanos sensor and obviously is there a spark at the plugs. If you have compression fuel and spark it should at least try to start even if the Vanos timing is out Is the MAF plugged in and OK Good Luck Dave
