Hi
With this very wet weather recently its not surprising that the car is a little damp, but twice now has water actually poured in, from what looks like under the dash into the foot wells. This has happened worse on the drivers side but a little pours into the passenger side.
Is this a design fault, the fact mini`s don't like water or is the car missing a bung or seal which is causing this.
I`ve not yet been able to pull back the carpet. Just wondered if anyone else has had this issue with a R50?
Many thanks
Toni
hi toni :)
i had something very alike on my old audi tt found out that a seal/rubber cap aprox 4'' by 5'' had corroded , it was so bad it started to rust the bulk head replaced cap ok.
i dont no any thing about minis, but look for a hole on bulk head :unsure:
      520d advice
    3. 13
      Fuel rail pressure problems.
      Would you buy this car?
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
