does anyone have any recommendation's for dump/blow off valves for a bmw 1 series 118d m sport? and any good tuning boxes?
thanks
I don't think you can fit a dump valve straight on a diesel because there's no vacuum from the throttle body. You need to make up a vacuum system you might need to google it or someone here will defo know. As the box if you want good cheap one from eBay look at tdi tuning ones for around £80 but for the best results your looking at a remap egr delete and catalytic converter delete also. I have a little knowledge on diesel tuning but I think that May give you some scope on what you need to start out.
      3.0i starter motor
      Bmw x1 2012 won't start
    3. 6
      X3 2.0 automatic
    4. 6
      X3 2.0 automatic
    5. 0
      Water leak at sharkfin aerial
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
    • Karlos70 earned a badge
    • DDONNY earned a badge
