The heater has finally stopped in the car never been the best since I had the car fisrtly only heat from drivers side then yesterday fans stopped working so checked fuse all good after a bit of research Im thinking it's the heater control valve just a couple of questions do I have to bleed and refill the coolant after replacing and do I need to replace both the control valve and the auxillary pump underneath it ie are they connected any help much appreciated
Cheers Paul
If you're disconnecting any coolant/heater hoses then you will need to bleed afterwards ;)
      Tyres for front of my 240i
    5. 0
      520d advice
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
