hi would anyone have any clues to why my drivers side tyre rubs and not the passenger side when both sides are the same dont know if this problem been a topic before if it has cant find it i have 255 tyres on the back which as far as i know should fit fine also have new suspension all round.
Guest Mr.Beemer
new suspension you mean shock absorbers & coil springs >
what aspect ratio is on your 255 tyre ?
in some cases the geometry can play a part -
yes i put coil-overs on all 4 legs and my tyres are 255/35 yr 18 avon zz5 it just seems strange that the offside rear rub and not the nearside at all,im going to get the wheels tracked,balanced and camber done at the weekend to see if i can sort it even though i had them done about 6 months ago,ive heard about other people having the same problem but haven't found a resolve yet.
Guest Mr.Beemer
was it rubbing before the coil overs were fitted ?
Guest Mr.Beemer
its worth getting the rear end geometry checked out with camber & see if something is bent or worn.
sometimes cant tell with the naked eye'
hope this sorts out for you -
Guest Mr.Beemer
i have heard of tyre rubbing when passengers are in the rear.
generally it comes down to the shocks but you have changed them
hmmm - :unsure:
If this is only the fronts then I have to suggest "Toe" alignment via steering-rack tie-rod on the offending side !
Is it scrubbing on the inside-edge ? If it is then I would imagine either the trailing arm bushes are worn or something more sinister like something bent !
it is rubbing on the outside edge of rear offside but not at all on nearside going for mot tomorrow so any faults should be picked up
Weird one Tony :wacko: Let us know what the geo-check comes back with ;)
the geo check for right rear came back as -1 46 camber and 0 13 toe the left rear is -1 09 camber and 0 15 toe
There's a fair bit difference in that, have you had it matched up and did it resolve the rub?? I would of thought this would of shown itself on the tyre wear for that side...
Those figures suggest its been kerbed at a lateral angle (handbrake slide??)!!
it failed its mot on the dreaded rear fuel pipes getting them done friday but no other advisers so ive asked him to look at my rear wheel set up to see if he can see anything
      3.0i starter motor
    4. 0
      Bmw x1 2012 won't start
    5. 6
      X3 2.0 automatic
    • BLM06 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
    • Karlos70 earned a badge
