hi there, new to forum so I hope im posting this in the right place ,,
I have a e87 118d 2004 , not long got the car wen I got it had these problems ,
01-Rear windows do not work, never got them to go down ever . "cc-id 259 anti trap deactivated"
iv tested all switches "left rear ,right rear and front right " an are all fine and illuminated ??
02-rear window wiper not working at all or the rear water washer jet,
iv cleaned out the washer bottle, tested the water washer pump "its works fine" iv unblocked the nozzle but still wont work iv tested the motor by putting 12v to it an it works fine but will not work when I push the right stork forword nothing happends ??
any help would be grateful thanx chris
I'll start with the easiest...
02 - Wiring/fuse fault
01 - WCM fault I think... Is there a disable button in the front?
All fues are good , and there is disable butten to stop the rear buttons from opening the windows but windows don't work with the butten on or off ???
WCM ?? What is this ?
Hmm wondering if you need a new switchpack matey ;)
Switchpack = This is the cluster of buttons to operate any/all the windows from drivers seat...
WCM = Windows Control Module (behind dashboard)
It has been known for the comfort relay to also cause these issues ;)
      Alloy wheels
    • SteveC51 earned a badge
    • Dan_C earned a badge
    • Gouden earned a badge
    • Markc earned a badge
