New Member
Bmw angel eyes
Hi Dave Sorry to be a pain if it was the bulbs how come when I swap the tms modules from one side to the other neither work but when I put them back in sides they come from originally then the passenger angel eyes work again Many thanks -
Bmw angel eyes
Sorry to be a pain but what would cause both sides to no work whe I swap the tms units from one side to the other if was the bulbs? -
Bmw angel eyes
Hi Dave many thanks am I wrong in thinking the bulbs are built in and have to break the headlight apart? -
Bmw angel eyes
Hi Ben Back home again the code you have is pointing to the LED bulbs for the angle eyes are faulty. There are 2 in each headlight. Just replace them with new ones and make sure the semi transparent seals are there to avoid water ingress. Then initialize the headlights via ISTA and all should be good. Dave -
Bmw angel eyes
Ok great thank you I've had it code read and it said fault code 805e3a daytime lights voltage lower than target value if that helps anymore?
