Driving home from work wen all of a sudden the clocks went off no lights no speedo no rev counter nothing (no power ) the car still drove an go me home but now will not start still nothing it's as if there no power going to the clocks , wen I put the key fob in the radio comes on and that's all that happens wen I hold clutch down and push the start button the radio go off I've tired my spare key but it's the same My friend with a code reader came down and plugged the car in but the obd isn't powering up the code reader ????
GOOD NEWS
Stripped out the glove box started to dig about by the fuse box and there the problem was ecu that push fits in to the fuse box had slid out about 5mm pushed it in an all sorted !!! Thanx Chris
      Alloy wheels
    • SteveC51 earned a badge
    • Dan_C earned a badge
    • Gouden earned a badge
    • Markc earned a badge
