Hi all
Just need a little advice if i may. Basically i bought a 2001 320d touring. Tbh i really like it, very comftable. Yet there are a couple nagging things i have found.
First, the rear wiper doesnt work and im not sure if this is a common fault or not.
And secondly which is the big one is that im told that the front cat pipe is cracked. Im being told that its a minimum of a 400 quid job. Can anybody verify that? Just want to make sure that im not going to be ripped off.
And through my own fault i need a new front bumper lol
Any help would be gratefully received.
Thanks
Hi Damian...
Rear Wiper - If you don't have a tester to check continuity then... Strip-out the panel and run a separate live to the motor to see if that operates it, if it does then it'll be a switch/fuse/wiring fault.
Catalytic converter - These babies are NOT cheap :(
Sad news lol. Was hoping that somebody was just trying to make more money off me lol. Thing is the car i actually think is worth it. I have a mate who runs a bodywork shop so i was going to get all the little marks taken out etc.... Think i may just keep shopping around and just get it done lol
Thanks for the reply though, much appreciated.
400 quid IS high mate, more like half that !
See 200 i could live with easily lol. Just on the last service the guy wrote on the receipt 'cat front pipe cracked'
Maybe just the down-pipe itself then, have it welded ;)
Guest jeffthro
+1 with Jim on the cat, quite possibly a welding job if just cracked and no corrosion.
Just had it looked at. Completely ruined lol, 520 to sort out. Im looking at alternatives lol
Guest jeffthro
Go get other quotes, bud. £520 for one section of exhaust plus cat is crazy. Go to a welding specialist and see if they can quote you for rebuilding the existing cat with a new pipe section? There is a great company down here in East Dorset called Tricketts Welding who are magicians, maybe you've got someone similar up there?
      My new E64 650i
      2009 X5 E70 35D
    4. 5
    5. 0
      Would you buy this car?
    • Amk earned a badge
    • Glyn6653 earned a badge
    • John perr earned a badge
    • Martyn58 earned a badge
