Hi Everyone
Replaced key battery still can't unlock car
First post, just bought a 2019 1 series sport. Replaced the key fob battery as requested, but the key still doesn't work for unlocking/locking car. It's still asking me to replace the battery, read this goes after a few cycles of locking and unlocking. Locks/unlocks fine on mybmw app. Does the Key need resinking, not sure how long it would have been flat for? TIA -
Cost of service 420i
Anyone know how much an 18000 mile service should be on a 420i wondered if I should go for the BMW maintenance plan? they want to charge £935 for two services in the plan -
6
Rear View mirror has come off windscreen screen
Hi all, I got the adhesive that was recommended in a you tube video with instructions, it was from Permatex. I had to ensure I removed the old adhesive from the silver disk first which took some doing but needed a sharp knife and a razor blade to lift it all. There was no adhesive debris on the wind screen. To fix I then used a wipe supplied in the kit and used a small amount of the adhesive also supplied. The bond took less than a minute. You do need to be sure of the location as the bond is very quick so ensure you can locate the mirror accurately otherwise it is going to get messy. N.B. I had to remove the two connectors to ensure the mirror could be located properly. It was a little fiddly getting them out but went back once mirror was fixed to the windscreen. A good experience though for me and mirror is back on with the accompanying casing parts also.
