Morning Ken Welcome to the Forum Depending on exactly when your car was built the PDC location changed. According to ISTA cars built before late 2010 the PDC module is in the Boot below the fuse board. LCI models and 2011 on it seems it was integrated with the Junction Box Module which is below the fuse board under the Glove Box the smaller plug A4010a is the PDC connector Dave -
Bmw angel eyes
Morning Ben The TMS units are probably coded Left or Right when you swap it you need to initialise the Headlamp unit using ISTA or another coding application if you have it I have never done it myself so just reading TIS and WIS from my copy of ISTA which is good up to 2019 when BMW decided to pull the plug Is there no help on You Tube normally quite a few Video How Too's there Hope this helps Dave -
10
Bmw angel eyes
Hi Dave Sorry to be a pain if it was the bulbs how come when I swap the tms modules from one side to the other neither work but when I put them back in sides they come from originally then the passenger angel eyes work again Many thanks
