Cholmondeley Pageant Of Power 2014
No emergency door lock
Hi my Battery is flat, my fob does not work. Removed caps at the side of the door handles, no emergency keyholes/locks present. I do have the fob keys, but no lock to put them in. BMW 420d 2014 Any ideas how to get in the car? Any help appreciated Thank you -
6
Morning Alexander Welcome to the Forum Paul used Liquid Moly additive I beleive, do remember that if the seals are hardening through age this will work if the seals have gone it can't do much Dave
