Bmw Stickers
BMW G30 Parking Brake error
Hi, my car suddenly gave an orange error parking brake. When i used the ISTA tool and diagnose it. It gives 2 errors about it. - D35CBA ( electrical parking brake switch fault , DSC-LIN 0x2B) missing - D35CCA (electrical parking brake switch fault , DSC-LIN 0x1) missing When i stop the car and open my door it automatically uses the handbrake and it works fine but other then that, i cant use it.. even the auto hold. If anyone can help me it will be perfect. Thank you -
Thank you for your response Dave, I have been to BMW Dealer but all they say computer indicates 'no faults' although I had frequent warnings saying system was restricted. They refuse to road test it saying it is dangerous to road test which I dispute as the system should give a visual warning at 8 car lengths and low speeds. I suggested to test it against another BMW with the same system but again they will not. If I have it on the most sensitive setting and get no warnings what is the point of the less sensitive settings. Lots of unanswered questions with this system?
