E46 coupe 325ci
Everytime i change up through gears 1 to 3 (3 to 4 if i go fast enough) i get a knocking /slapping noise from the righthand side of the drivers footwell, been all over the underneath, checked numerous bushes but cant find a thing, it only does it when i go to change up through the gears not down and not if i just dip the clutch,can anybody please help i dont know where else to turn,mark
Have you checked your gearbox mounts? I mean literally checked them, not just visually. There are two rubber mounts under the gearbox that may look sound but have sheared off their base plates, this happened to me.
      520d advice
    3. 13
      Fuel rail pressure problems.
      Would you buy this car?
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
