Hi all from milton keynes have a 3 series 09 plate tidy little diesel, its completely standard bit looking to add a sub and amp in the boot but dont want to change the head unit is this possible at all?
Guest Mr.Beemer
welcome to the forum - :)
it may be possible but as far as I know if you change the head unit you will get more/better sound with an amp from it. the standard unit has a built in amp too.
theres no phono leads output for the standard unit so you will have to use the crossover box and wire it up.
best way, change the unit -
      Newbie here
      Appears no fire
      Appears no fire
    4. 12
    • Larry36 earned a badge
    • Graham J earned a badge
    • Sogra earned a badge
    • Aaronelvis earned a badge
