Fresh Blood
Bmw angel eyes
Hi Ben Without carrying out a full test on each TMS it is difficult to say. I would check the internet for any test criteria then start with the good one note the results then test the faulty one to compare. All I found on the TIS is it is likely to be the LED's (2 of them) how simple it is to change them I have no idea. As an Example I recently had a failed Halo/Parking lamp on my E70 checked ISTA says remove cover 3 screws remove 2 further screws and the lamp is out Ha Ha Ha. What i discovered in WIS was a note that says remove Headlamp from the car to access the screws. Dave -
9
Bmw angel eyes
Hi Dave Thanks for your reply no can't seem to find any videos is it likely the angel eye led inside the headlight have failed then going by that fault code? Could it still possibly be the tms ? Many thanks Ben -
10
Morning Ken Welcome to the Forum Depending on exactly when your car was built the PDC location changed. According to ISTA cars built before late 2010 the PDC module is in the Boot below the fuse board. LCI models and 2011 on it seems it was integrated with the Junction Box Module which is below the fuse board under the Glove Box the smaller plug A4010a is the PDC connector Dave -
9
Bmw angel eyes
Morning Ben The TMS units are probably coded Left or Right when you swap it you need to initialise the Headlamp unit using ISTA or another coding application if you have it I have never done it myself so just reading TIS and WIS from my copy of ISTA which is good up to 2019 when BMW decided to pull the plug Is there no help on You Tube normally quite a few Video How Too's there Hope this helps Dave -
10
Hi, I have a problem with my 2011 X5 front parking sensors. I have used an OBD reader to check the failure codes and it appears all 4 front sensors have a ground or open circuit fault. I have checked the wiring harness for the front sensors and the main plug behind the bumper and all seem fine with no damage. I assume this must be the PDC module as it’s all the front not the odd sensor. But I cannot find it anywhere. can any one help please?
