New Member
Front shocks
420i STAGE 1?
Morning Jim Welcome to the Forum Try Disconecting the Battery for 20/30mins (Dealer Trick) to see if it resets then. If not you could have a faulty wheel sensor a Diagnostic check will tell you Dave -
Front shocks
Hi all, Can anyone please direct me to the front shocks I need? Appreciate the help Kieran -
420i STAGE 1?
I am wondering if it is worth it to get a stage 1 tune on a bmw 420 2019 f32 model, I have heard it makes them a lot more responsive and fun to drive but also that the 20i engines aren’t exactly built strong enough to be pushed that far as the stage 1 brings it to around 250bhp I believe. Do you think it’s worth it or is there any way you can strengthen the engine for the tune?
