Hi, I wonder if somebody could give me some help on where to purchase the correct hubcentric wheel spacers to fit my LCI E93 325d.
I did have some bmw specific 10mm hubcentric spacers which fit the Hub diameter and PCD however the actual hub's centric ring protrudes 13mm preventing the hubcentric spacer from sitting flush on the hub surface. I attempted to bolt on the wheels anyway just encase the spacer was tapered slightly and even tho the wheels bolted up tight enough to drive the car, what had actually happened was the Hub's centric protrusion extruded the hubcentric ring of the spacer to the point the ring actually fell off! Making some pretty perfect Non-hubcentric spacers. However, this is no good to me as i had some pretty bad wheel vibrations above 60mph.
Where can i purchase some 10mm (or 13mm pref) hubcentric spacers that are milled inside to accept a 13mm protruding hub centric ring.
I have supplied pics of the spacers i had, how thick and what happened.
Many thanks for your help.
Ryan
post-9809-0-74443800-1414848947_thumb.jp
post-9809-0-10727400-1414848970_thumb.jp
post-9809-0-81140200-1414848992_thumb.jp
post-9809-0-69610400-1414849011_thumb.jp
      Price
    5. 3
    • Jlou17 earned a badge
    • JCDenton earned a badge
    • Luke330 earned a badge
