First Post - Auxiliary Power Sockets Not Working
APX5
Hi
This is my first post as I have just signed in. Please bear with me if I am not doing this correctly.
I have a 2007 X5 3.0D. My Cigarette lighter socket nor the additional two Auxiliary power sockets work. I have tried checking these with( working) phone chargers etc. I have also checked fuses which are fine ( In the front as well as in the back).
I am quite baffled by this. Can anyone please help?
I will really appreciate it.
Thanks
Have you checked fuse 54 20 amp it is hidden behind the fuse box in the glove box and from what I been told a real mission to reach.
You can check www.realoem.com put the last 7 digits of your chassis number in, Good Luck
Hi Greydog
I have checked the 20 Amp fuse under the glove box. You are right, it does need some doing to reach there. 3 screws to remove and then on green to twist.
All 20 amp fuses were good. One "118" in the boot was missing and I replaced it but did not produce any result. Interestingly all three power sockets ( 1 cig lighter and 2 Aux power outlets) are not working. Is there one master fuse for this ? I thought 118 was the one but did not help.
I am enclosing the fuse placement diagram I have in my car.
Any suggestions please?
Thanks once again for reading
post-9874-0-09529300-1415279665_thumb.jp
post-9874-0-62275700-1415279668_thumb.jp
From what I understand yes Cig lighters and power outlets are all linked. You need a wiring diagram to be able to check, I would guess that there has to be a relay in the mix somewhere. Have you checked the fuse/relay box in the engine bay? Passenger side up by the windscreen.
I haven't looked at realoem to see if there is any help there (its helped me a couple of times) or search for wiring diagrams on the net.
One thought my Nav stopped working (no power) I checked and cleaned all the normal things connections and fuses no joy I thought of replacement then as last try I changed the fuse all back to normal?? The fuse I removed tested OK weird.
      BMW 125i E88 - Passenger Mirror Fault (RHD)
    2. 6
      LED adaptive headlight / high beam failure warning
    3. 6
    4. 6
    5. 6
    • G1000 earned a badge
      Reacting Well
    • AAJS earned a badge
    • Paul Ibb earned a badge
