4.6Is Engine Needed!
DPF Cleaning fluid
Hi, I have a warning on my dash that the DPF unit needs attention. I assume this means it requires regeneration. Any pointers on best type of additive fluid to use for this and what is the most successful procedure, Thanks Paneuro. -
97' IL for sale
Going by that really enticing and highly detailed description, colour me not very interested. If you want to sell it as Reacher would say "details matter!" -
28
Gear box failure
Morning all, I'm a new member joining the group because I have read the issues in this thread and am also experiencing the same. Mine is. 220d 2 series active tourer from 2016. I also have play in the drive shaft on the near side and some oil around where the drive come out of the gear box. Mine is the aisin 8 speed. Has anyone collectively contacted BMW regarding this matter. I've heard BMW recalled this gearbox in New Zealand, so there is a precedent. -
Running Boards
Thanx for your response Dave I will follow up on your suggestions. Cheers. -
Running Boards
Morning Mick Welcome to the Forum First question why not OEM running boards ? You would then know they will fit here are the OEM parts and fixings If you take a look at www.realoem.com put the last 7 digits of your Vin into the search box and it will bring up your model. Then search Body section Once you have all the correct part numbers you can search the Internet for the best supply (remember you need Left and Right parts) You should find parts from BMW Breakers as well as contacting BMW Dealers to see what their prices are like (sometimes a pleasant surprise) Dave
