Generally takes 3 tries to get the 320d fired up from cold, this was never the case before hand. Once she's up and running, no further problems apart from a potential and common thermostat issue with the car running cooler than normal.
I'm assuming glow plugs or injectors. I was going to go with glow plugs first because they are cheaper. I've looked it up and doesn't seem as simple to change as first thought. I did the swirl flaps so from what I see it's basically to that point again.
I don't have a code reader, but if I were to get a cheap one that does the trick which one would people recommend?
Cheers in advance
Tom
      Price
    5. 3
    • Jlou17 earned a badge
    • JCDenton earned a badge
    • Luke330 earned a badge
