"My car driving total deviation to the
right, made a few orientation or deviation, how to solve?" Experts, the
cars with the deviation is relatively common problem.
1. The four
misregistration. In most cases, by doing wheel alignment can be solved, but if
you do wheel alignment can not be resolved, it must be other causes.
2. The sides of the
tread pattern is not the same or a deep one shallow not as high. The whole car
is best used the same type of tire, front axle and rear axle at least two tires
must be the same, and tread depth must be the same, more than the wear limit
must be replaced.
3. sides of the tire pressure range. Tire
pressure tire will become unequal sample sizes, scroll up and bound deviation.
The deformation of
the spring on both sides of the front adjustable
coilover
cushion inconsistent. Comparable to judge the quality of the
shock absorber spring by pressing or after removal.
5. Front shock
absorber failure. After the failure of the front shock absorbers in the vehicle
in two hanging one high and one low, discontinuity, leading to deviation.
Special damping tester can detect the degree of absorption dampers, shock
absorbers or bad judgment; as unconditional removable, with stretch the way to
judge.
6. vehicle chassis
components is not normal wear and tear is too large a gap exists. Steering Con
rod
ball, the support arm pouches, pouches and other stabilizer bar is a
common part of the gap is too large and easy, trucks should be carefully
examined.
7. The brake of a
wheel return poor separation incomplete. This is equivalent to one side of the
wheel is always part http://www.maxspeedingrods.co.uk/high-performance-mitsubishi-eclipse-evo-4g63-4g64-100mm-stroke-7-bolt-4340-en24-chrome-moly-billet-crankshaft.html of the brake is applied, the vehicle is bound up with
deviation. Inspection, can feel the wheels of temperature, such as a wheel than
a lot of other wheels, indicating a return to the bad brake wheel.
8. Frame overall
deformation. Both sides of the wheelbase difference is too large, exceeding the
maximum allowable range, can be measured by a tape measure; as beyond the scope
must be corrected by the correction units.
Recommend blog http://jolin.mixform.com/
    4. 5
