Most of the original owners want to
improve the performance of the best car through a series of modifications, can
also lead to the frame and therefore did not expect variations. What is the
reason? As everyone knows, are the source of all modifications from the hub.
Replace the wheels have to bring many
benefits with wide flat tire to achieve results, but a flat tire caused by
ground shaking filter needs to be replaced, but the suspension was filtered;
the choice of hanging soft suspension failed to play the best condition, so the
bias stiffer suspension as the preferred, more rigid suspension shock filtering
effect is unsatisfactory, the results of the vibration is transmitted directly
to the frame, the frame variants over time lead.
● all start because of wheel
General Tire factory models offer
material for tire rims, although durable, but the general appearance; and,
relatively speaking, alloy wheels light weight, small inertial resistance,
making high precision, small deformation at high speed rotation, will help
improve straight running Auto Performance Parts,
reduce the tire rolling resistance, thereby reducing fuel consumption. Thermal
properties of the alloy material is about three times the steel, heat
dissipation, for a vehicle braking system play a role.
Seemingly modified wheel has a number
of benefits, if equipped with narrow tires, the tire is too thick, the tire
size is too small to be difficult to play the advantages of the hub, so a large
width and small thickness with modified wheel tire becomes inevitable choice.
● For best results replace tires
For the sake of play the best
performance, increase the ground contact area of the tire may improve adhesion
between the tires and the brake, bend performance is improved. The low profile
tires can reduce tire deformation on handling produce, so more direct control
response, sensitive, and indeed from the appearance is very beautiful, but too
thin tire vibration through the ground to produce the effect of filtering very
poor, then the need to replace a filter shock suspension racing
coilovers
● consequences appear to replace suspended
Tires for retrofitting after poor
ability to shock, can only be achieved by replacing the suspension filtered
shock effect. If you choose a softer suspension shock absorbers poor problem
can be solved, but the car's performance will decline, softer suspension in
cornering, braking vehicle big swings, for the replacement wheels and tires
simply spoil such a suspension.
  • 2 months later...
