M60 Aluminium Water Pump Plate
Bmw angel eyes
5
Bmw angel eyes
Hi Dave many thanks am I wrong in thinking the bulbs are built in and have to break the headlight apart? -
5
Bmw angel eyes
Hi Ben Back home again the code you have is pointing to the LED bulbs for the angle eyes are faulty. There are 2 in each headlight. Just replace them with new ones and make sure the semi transparent seals are there to avoid water ingress. Then initialize the headlights via ISTA and all should be good. Dave -
5
Bmw angel eyes
Ok great thank you I've had it code read and it said fault code 805e3a daytime lights voltage lower than target value if that helps anymore? -
5
Bmw angel eyes
Morning Ben You need someone with ISTA/INPA Diagnostics as that will also in WIS (Workshop Information System) and TIS (Technical Information System) I will look later but just back from the Horses and now off to Dog Training when home I will fire up the Garage Laptop and see what I can find Dave
