On my 2010 x5 the water jets for the windscreen are only firing up the screen around 3rd of normal power, any clues please ??
Clogged pump filters would be my bet, some screen washes leave a scummy residue that clogs the filters not restricted to BM's I have had it with Merc and Volvo as well
Just looked on realoem your car has 2 pumps item 5 & 8 filters 6 & 9
It looks very similar to mine you need to almost empty the washer tank to save losing to much fluid (that or park over a drain) take out the pump and wash the strainer/filter and put it back straight forward enough job
Afraid so I did mine when I was down to almost empty on the washer tank. Both my filters were clogged with a white scummy gunge, not difficult to clean just a pain having to almost drain the tank. It was a year ago I did mine.
You can see the filters on the drawing they push fit to the bottom of the pump
    2. 6
    3. 14
    4. 13
      SLIPPING CLUTCH
    5. 13
      SLIPPING CLUTCH
    • Karlos70 earned a badge
    • DDONNY earned a badge
    • Dimitris earned a badge
      Collaborator
    • DAW90 earned a badge
    • jn1253 earned a badge
