Ok can somebody please help me.
I have replaced the rear wiper and arm but the water just runs down the back of the car and cleans the bumper.
Is it possible there is something missing from the parts I have fitted.
Thanking you in advance
Hi Malcolm,
When mine stopped working I took off cover on inside of hatchback then took off plastic T piece (joining pipe) off and prised open to find small soft rubber disc inside, I removed this and water was streaming out when used.
Try this and see if it works for you too, good luck,
jeffers
Jeffers
thanks water now running freely but not onto the rear windscreen.
Any more ideas very welcome.
Hi Malcolm,
Pleased its working, now you have to twist the little jet hole water comes out of with pin or small screw driver towards window very small bits at a time then you will hit window with water.Its very fine adjustments you need to make, have fun.
jeffers
Hi jeffers
mine does not have a a little jet hole , the black cover has a 25mm slot in it and nothing else
the little jet hole is on the wiper arm at the end which you can pull up to expose the locking nut, if not then it is missing from your wiper arm, if so you need an old wiper arm purely for the plastic jet which pushes into the hole on your wiper arm. A new one is only about £7 which will come complete.
jeffers
      Bmw x4 2015 angel eyes
      Steering lock query
    3. 4
      E66 730Ld with issues
    4. 0
      850i for sale no reserve
    • Mikeyladders earned a badge
    • Super Bmw earned a badge
    • drew lemke earned a badge
    • bpd1984 earned a badge
