  • 4 months later...
Hi
You got 2 pumps on the e39 one inside the tank which is a primary pump if that's ok most likely to be the inline pump under the plastic trim under the near side of the car.
Hi
You got 2 pumps on the e39 one inside the tank which is a primary pump if that's ok most likely to be the inline pump under the plastic trim under the near side of the car. g.pngg.png
Thanks for answer, I will try it
      Front shocks
      420i STAGE 1?
    4. 5
    5. 0
      Engine mounts
    • kieran14 earned a badge
    • BilboBaggins earned a badge
    • Jim cameron earned a badge
    • Mish earned a badge
    • melon7 earned a badge
