Hi Guys could any advise me if a 57 plate Mini One has blue tooth as standard and if not what do you system do you recommend to put in the car.
Thanks in antisipation
Alan
Always depends on the spec of the car... usually not on this age of car.
I am more than happy to check if you can supply the reg.
My E90 didn't have Bluetooth, so I installed a parrot kit.
James
James
Hi James All I know at present that the car is a MIni 1 pepper pack 57 plate hope that helps is a parrot kit easy to install
Alan
Would really need to be checked with the reg/chassis
Parrot kits are usually installed by "professionals" - it isn't a BMW thing.
There will be guides on the web and possibly on YouTube
James
    • DAllen earned a badge
    • Peter 255 earned a badge
