E46 330D Auto Won't Rev About 3000Rpm!
filter change recomendations
Thanks for your input. I checked the the DC Voltage with a meter on either side of the fuses (152 and 182) on top ,so I know the fuses are good I also checked the relay 'on the bench' and it's functioning too. Maybe the car needs a reset with a BMW Diagnostics kit as there is still an icon on the dashboard which will not clear? -
Hi Les Welcome to the Forum As this is a UK based site we may not have to many members near you A Diagnostc Scan may help to tell you more, or maybe an Automotive Electrician can advise You could check all the earth points BMW love mutiple earth points and earth switching Good Luck Dave
