The engine management light (the engine shaped warning light, not the circular EML light which I believe is the fly by wire throttle light) DOES NOT come on when I turn the key prior the starting the car.
I have scanned the car for faults using a C110 scanner which did reveal a faulty MAF which I have since replaced...but nothing else.
I have removed the instrument console to check for any foul play but found nothing
I since performed an instrument console test check which showed that the engine light will illuminate
Now I am a bit confused/stumped
Any ideas? ECU?
Many thanks in advance
HB
    2. 6
    3. 14
    4. 13
      SLIPPING CLUTCH
    5. 13
      SLIPPING CLUTCH
    • Karlos70 earned a badge
    • DDONNY earned a badge
    • Dimitris earned a badge
      Collaborator
    • DAW90 earned a badge
    • jn1253 earned a badge
