MOT Jan 2016
5 Green Bars on Service Indicator
HPI Clear
Chain Driven
2 BMW Keys
Torch in glove box
First Aid Kit
Mileage 160,500
FSH (Mostly BMW)
Alarm & Immobilser
Black napper leather interior with silver trim
5 Speed triptronic intelligent gearbox with sports mode
19" Parallel alloy wheels & 5th alloy as spare
Widescreen Sat Nav
Widescreen TV but analogue requires updating to digital
Lowered on Apex 60mm springs
Auto headlights
Auto wipers
Auto dim rear view mirror
Xenon's head lights
Traffic master (Needs subscription to activate it)
Full closure
Full Electric Sunroof
Full electric driver's seat with 3 memory settings which controls drivers seat, steering column & both mirrors
Full electric passenger seat
Electric front and rear windows
Electric Adjustable steering column
Electric mirrors with passenger mirror tilts down in reverse
Multi-function steering wheel with cruise control, handsfree and controls for audio system
Headlight washers
Park Distance Control front and rear
Bmw business radio with 6 disc changer
Remote central locking
Dual climate control
Power Assisted Steering
Dynamic Stability Control
Antilock Braking System
Front and rear mud flaps
Gold brake callipers
Genuine BMW M5 mesh with Hamann 110mm trumpets
Tool kit
BAD POINTS:
Car drives perfectly but when braking from 40mph - 25mph there is slight steering wheel vibration. Disc brakes & brake pads have been changed, brand new tyres on the front and balanced. Front hub bearings & stabiliser links changed. Below and above those speeds the car drives perfectly. However, it is intermittent.
A BMW specialist emailed me the following solution: The 5 series has MacPherson struts on the front and even though the bushes don't look worn they indeed are which causes the steering wheel to wobble at certain speeds. To stop it you have to change the 3 arms on both front wheels.
Another BMW specialist emailed the following solution: You need to change what is called console bushes or on bmws they are more know as lolly pop bushes you can get them from euro car parts for around £12/15 per side.
The radio has stopped working. The Radio Module is most likely at fault.
There is a bit of paint bubbling on rear of roof & minor rust on 2 wheel arches.
Passenger side rear panel has been resprayed due to someone putting a deep scratch. The panel is slightly dull & can only be noticed at certain angles. Just needs to be buffed up to bring it back to a shine.
      Alloy wheels
    • Gouden earned a badge
    • Markc earned a badge
    • Neil Stokes earned a badge
    • Mish earned a badge
    • Paul M went up a rank
