Help. Think I've Brought A Lemon
Engine noise
As you have a noise which worries you clearly it isn't perfect, and the belt area needs checking/attention Dave -
6
6
BMW X5 E70 2013 Starting Issues
Hi Ali Your first code I believe is Glow Plug controller related, either the Glow Plug controller or its wiring Second is normally Transfer case or Lin bus related The last is not one I have ever seen before fingers crossed its related to the other 2 I would start with the Glow Plugs and Controller not an expensive job but a fiddly one as the Inlet manifold has to come off to get at them. Allow yourself plenty of time as the Glow plugs are a known problem soak them in release fluid for a couple of hours first. The Glowplug controller is still awkward to get at on the side of the engine below the glow plugs the total job I would rate a 6 (1 being easy 10 being a complete Beech) Next I would check the electrical connections at the Transfer Case make sure they are clean and made correctly Then when its back together make sure the Battery is fully charged reset all codes and start then scan to see what comes back Dave -
6
Hi Dave, Codes are; 1. 49A6H/18854 Undocumented Code 2. 4C3C Message 3. 4C12H/19474 Undocumented Code Not sure, just purchased vehicle… no book 🤦♂️ -
5
Engine noise
No everything with the car is perfect apart from this worrying noise 😔
