Help Needed....! 330d Lci Swirl Flap Plausability Fault
hi Dave, I had a look there and if its there I couldn't find it, the only other place it seems to suggest is to do with the BC button on the indicator lever but I have tried that as well and no joy, it may be that there is some sort of procedure which has to be followed in the right order but until now I am at a loss. cheers Paneuro. -
7
7
7
Mileage
Morning Bubba Are you telling us your indicated mileage has risen from 63000 to 180000 ? If that is the case then it needs some checking, BMW store mileage in 2 places the Instrument Cluster and the Footwell Control Module it could be that one or the other has been changed but not registered to the car correctly and now mileage has reverted to it's original or it could be the car was clocked at some time in it's life Dave
